[postgis-tickets] r17733 - Fix perl syntax
Sandro Santilli
strk at kbt.io
Tue Aug 20 02:24:39 PDT 2019
Author: strk
Date: 2019-08-20 02:24:39 -0700 (Tue, 20 Aug 2019)
New Revision: 17733
trunk/regress/run_test.pl
Fix perl syntax
Can't "last" outside a loop block ...
Modified: trunk/regress/run_test.pl
--- trunk/regress/run_test.pl 2019-08-20 09:03:46 UTC (rev 17732)
+++ trunk/regress/run_test.pl 2019-08-20 09:24:39 UTC (rev 17733)
@@ -1367,7 +1367,7 @@
if ( $OPT_WITH_SFCGAL )
- do {
+ do {{
my $sql = "CREATE EXTENSION postgis_sfcgal";
if ( $OPT_UPGRADE_FROM ) {
if ( semver_lessthan($OPT_UPGRADE_FROM, "2.2.0") )
@@ -1387,7 +1387,7 @@
fail "Error encountered creating EXTENSION POSTGIS_SFCGAL", $REGRESS_LOG;
die;
- } while (0);
+ }} while (0);
return 1;
