[postgis-tickets] [PostGIS] #4485: regrssion test to test postgis_extensions_upgrade
PostGIS trac at osgeo.org
Tue Aug 20 08:27:53 PDT 2019
  Reporter:  robe                   |      Owner:  strk
      Type:  task                   |     Status:  reopened
  Priority:  medium                 |  Milestone:  PostGIS 2.5.4
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by strk):
 Manually testing the new support (I've added {{{ :auto }}} and {{{ :auto!
 }}} as upgrade-path targets)  it looks like postgis_extensions_upgrade()
 leaves raster unpackaged when coming from 2.5.0 or older, should we change
 this to re-package when needed ? The documentation says we do repackage,
 which is NOT happening (unless you call it twice).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4485#comment:8>
