[postgis-tickets] r17741 - Replace aliasing approach with blunt memcpy to avoid errors with some compilers
Paul Ramsey
pramsey at cleverelephant.ca
Tue Aug 20 11:18:43 PDT 2019
Author: pramsey
Date: 2019-08-20 11:18:43 -0700 (Tue, 20 Aug 2019)
New Revision: 17741
branches/2.5/liblwgeom/lwgeom.c
References #4319
Modified: branches/2.5/liblwgeom/lwgeom.c
--- branches/2.5/liblwgeom/lwgeom.c 2019-08-20 16:01:52 UTC (rev 17740)
+++ branches/2.5/liblwgeom/lwgeom.c 2019-08-20 18:18:43 UTC (rev 17741)
@@ -2494,28 +2494,21 @@
return bits_needed;
-static inline
-double mask_double(double d, uint64_t mask)
- uint64_t* double_bits = (uint64_t*) (&d);
- (*double_bits) &= mask;
- return *((double*) double_bits);
static double trim_preserve_decimal_digits(double d, int32_t decimal_digits)
- if (d==0)
+ if (d == 0)
return 0;
int digits_left_of_decimal = (int) (1 + log10(fabs(d)));
uint8_t bits_needed = bits_for_precision(decimal_digits + digits_left_of_decimal);
uint64_t mask = 0xffffffffffffffff << (52 - bits_needed);
+ uint64_t dint = 0;
+ size_t dsz = sizeof(d) < sizeof(dint) ? sizeof(d) : sizeof(dint);
- return mask_double(d, mask);
+ memcpy(&dint, &d, dsz);
+ dint &= mask;
+ memcpy(&d, &dint, dsz);
+ return d;
void lwgeom_trim_bits_in_place(LWGEOM* geom, int32_t prec_x, int32_t prec_y, int32_t prec_z, int32_t prec_m)
