[postgis-tickets] r17745 - run_test.pl: always repackage raster when upgrading via function
Sandro Santilli
strk at kbt.io
Tue Aug 20 12:29:09 PDT 2019
Author: strk
Date: 2019-08-20 12:29:09 -0700 (Tue, 20 Aug 2019)
New Revision: 17745
trunk/regress/run_test.pl
This is because the upgrade function invoked may be coming from the
a pre-split version and thus not know anything about repackaging.
See #4485
Modified: trunk/regress/run_test.pl
--- trunk/regress/run_test.pl 2019-08-20 18:33:34 UTC (rev 17744)
+++ trunk/regress/run_test.pl 2019-08-20 19:29:09 UTC (rev 17745)
@@ -1551,17 +1551,12 @@
die;
- if ( $upgrade_via_function )
+ # Handle raster split if coming from pre-split and going
+ # to splitted raster
+ if ( $OPT_UPGRADE_FROM && has_split_raster_ext($OPT_UPGRADE_TO) &&
+ ! has_split_raster_ext($OPT_UPGRADE_FROM) )
- # The function does everything
- return 1;
- if ( $OPT_WITH_RASTER )
- if ( $OPT_UPGRADE_FROM
- && ! has_split_raster_ext($OPT_UPGRADE_FROM)
+ if ( $OPT_WITH_RASTER )
# upgrade of postgis must have unpackaged raster, so
# we create it again here
@@ -1578,29 +1573,8 @@
else
- my $sql = "ALTER EXTENSION postgis_raster UPDATE TO '${nextver}'";
- if ( $OPT_UPGRADE_FROM =~ /^unpackaged/ ) {
- $sql = "CREATE EXTENSION postgis_raster VERSION '${nextver}' FROM unpackaged";
- print "Upgrading PostGIS Raster in '${DB}' using: ${sql}\n" ;
- my $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
- my $rv = system($cmd);
- if ( $rv ) {
- fail "Error encountered altering EXTENSION POSTGIS_RASTER", $REGRESS_LOG;
- die;
- else
- # Raster support was not requested, so drop it if
- # left unpackaged
- && ! has_split_raster_ext($OPT_UPGRADE_FROM) )
+ # Raster support was not requested, so drop it if
+ # left unpackaged
print "Packaging PostGIS Raster in '${DB}' for later drop using: ${sql}\n" ;
@@ -1621,8 +1595,32 @@
die;
+ if ( $upgrade_via_function )
+ # The function does everything
+ return 1;
+ my $sql = "ALTER EXTENSION postgis_raster UPDATE TO '${nextver}'";
+ if ( $OPT_UPGRADE_FROM =~ /^unpackaged/ ) {
+ $sql = "CREATE EXTENSION postgis_raster VERSION '${nextver}' FROM unpackaged";
+ print "Upgrading PostGIS Raster in '${DB}' using: ${sql}\n" ;
+ my $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
+ my $rv = system($cmd);
+ if ( $rv ) {
+ fail "Error encountered altering EXTENSION POSTGIS_RASTER", $REGRESS_LOG;
+ die;
if ( $OPT_WITH_TOPO )
my $sql = "ALTER EXTENSION postgis_topology UPDATE TO '${nextver}'";
