[postgis-tickets] [PostGIS] #4485: regrssion test to test postgis_extensions_upgrade
    trac at osgeo.org
    Tue Aug 20 12:29:10 PDT 2019
  Reporter:  robe                   |      Owner:  strk
      Type:  task                   |     Status:  reopened
  Priority:  medium                 |  Milestone:  PostGIS 2.5.4
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by strk):
 In [changeset:"17745" 17745]:
 #!CommitTicketReference repository="" revision="17745"
 run_test.pl: always repackage raster when upgrading via function
 This is because the upgrade function invoked may be coming from the
 a pre-split version and thus not know anything about repackaging.
 See #4485
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4485#comment:10>
