[postgis-tickets] [PostGIS] #4483: Can't upgrade from PostGIS 3.0.0alpha3 to 3.0.0alpha4 ST_AsGeoJSON
trac at osgeo.org
Wed Aug 21 10:06:35 PDT 2019
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by pramsey):
"tag", "release", we bundled out a release with this change already in
place, so if A was old and B was new, and A>B is broken, we can't really
fix it, right? B is broken and it's released. Also, changing back for C
would imply B>C would also be broken. But at least then C>D, D>E, etc
would all work.
We can change back, the only thing that "pretty_bool" is good for is
matching up to the json emitting functions in PostgreSQL which use
"pretty_bool" as the name for their pretty printing variable. I noticed
while adding the casts and decided to try to match them up and then we
ended up here (because why PostgreSQL cares so much about variable names
that you cannot change them in signatures? seems overly tight to me)
I still don't know what to do to fix this. I don't even know what test
you're running. If you're upgrading from the broken release to trunk that
won't work, right?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4483#comment:6>
