[postgis-tickets] [PostGIS] #4182: Unexpected TopologyException during ST_Union aggregate function with valid polygons
trac at osgeo.org
Wed Aug 21 15:37:44 PDT 2019
polygons
Reporter: blaggner | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS GEOS
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by mdavis):
Thanks for the test case. It does indeed trigger the error, in GEOS and
in JTS.
The reason for the error is that there are a LOT of "slivers" in the
dataset - i.e. polygons whose boundaries almost line up, but not quite
(the vertices are very slightly different to the adjacent polygon).
The good news is that this should be handled by the forthcoming overlay
code. The bad news is that the slivers will very much show up in the
output (typically as tiny holes in the middle of a large unioin polygon.
This may or may not be an issue depending on your intended use of the
data.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4182#comment:6>
