[postgis-tickets] [PostGIS] #4485: regression test to test postgis_extensions_upgrade (was: regrssion test to test postgis_extensions_upgrade)
trac at osgeo.org
Thu Aug 22 02:22:08 PDT 2019
Reporter: robe | Owner: strk
Type: task | Status: closed
Priority: medium | Milestone: PostGIS 2.5.4
Component: build/upgrade/install | Version: trunk
Resolution: fixed | Keywords:
Comment (by strk):
For the record: with latest commit the good bots are expected to fail, due
to {{{ make installcheck }}} now failing for the bug reported as #4486
(which will be fixed once we have a record of failure)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4485#comment:12>
