[postgis-tickets] [PostGIS] #4487: Split "check" rule in "check-unit" and "check-psql"
PostGIS trac at osgeo.org
Thu Aug 22 06:37:00 PDT 2019
  Reporter:  strk         |      Owner:  strk
      Type:  enhancement  |     Status:  closed
  Priority:  medium       |  Milestone:  PostGIS 3.0.0
 Component:  postgis      |    Version:  trunk
Resolution:  fixed        |   Keywords:
Changes (by strk):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"17758" 17758]:
 #!CommitTicketReference repository="" revision="17758"
 Split "check" into "check-regress" and "check-unit"
 Makes "installcheck" only run "check-regress"
 Closes #4487
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4487#comment:2>
