[postgis-tickets] [PostGIS] #4488: pg_restore: ERROR: relation "topology_id_seq" already exists
PostGIS trac at osgeo.org
Thu Aug 22 06:51:01 PDT 2019
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 3.0.0
 Component:  topology  |    Version:  trunk
Resolution:            |   Keywords:
Comment (by strk):
 I see there's no {{{ config_dump }}} call in either postgis/sql/postgis--
 unpackaged--3.0.0alpha5dev.sql or postgis_topology/sql/postgis_topology--
 unpackaged--3.0.0alpha5dev.sql so this might be a problem for core as well
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4488#comment:4>
