[postgis-tickets] [PostGIS] #4182: Unexpected TopologyException during ST_Union aggregate function with valid polygons
trac at osgeo.org
Thu Aug 22 08:55:00 PDT 2019
polygons
Reporter: blaggner | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS GEOS
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by mdavis):
Looking at the LostGIS overlay functions in more detail, it appears that
they drop back to using MakeValid, and failing that a very small buffer.
This is certainly one way to deal with issues, and it's nice to have it
wrapped up in a convenient function.
Actually using buffer( [A,B], 0 ) is an effective substitute for union(A,
B). Do you use that inside your safe_union?
And that makes me think it might be a useful fix to add to ST_Union
aggregate, to handle the failures which occur there.... Could be a quick
short-term fix to help older PG versions.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4182#comment:12>
