[postgis-tickets] r17766 - [travis] don't assume "make check" will work parallel w/out "make"
Sandro Santilli
strk at kbt.io
Thu Aug 22 11:07:17 PDT 2019
Author: strk
Date: 2019-08-22 11:07:17 -0700 (Thu, 22 Aug 2019)
New Revision: 17766
trunk/ci/travis/run_coverage.sh
Modified: trunk/ci/travis/run_coverage.sh
--- trunk/ci/travis/run_coverage.sh 2019-08-22 18:00:27 UTC (rev 17765)
+++ trunk/ci/travis/run_coverage.sh 2019-08-22 18:07:17 UTC (rev 17766)
@@ -8,5 +8,6 @@
/usr/local/pgsql/bin/pg_ctl -c -l /tmp/logfile start
./autogen.sh
./configure CFLAGS="${CFLAGS_COV}" LDFLAGS="${LDFLAGS_COV}" --enable-debug
+make -j
make -j check
(curl -S -f https://codecov.io/bash -o .github/codecov.bash && bash .github/codecov.bash) || echo "Coverage report failed"
