[postgis-tickets] [PostGIS] #4182: Unexpected TopologyException during ST_Union aggregate function with valid polygons
PostGIS trac at osgeo.org
Fri Aug 23 07:03:53 PDT 2019
polygons
  Reporter:  blaggner  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS GEOS
 Component:  postgis   |    Version:  2.3.x
Resolution:            |   Keywords:
Comment (by komzpa):
 Hey there,
 (I'm original author of LostGIS).
 I didn't do ST_Safe_Union because I didn't know back then how to build it
 as an aggregate that wraps aggregate.
 The reason the ST_Safe_* buffers geometries and not buffers them back was
 that there was a separate "deoverlap" build phase, and it was more
 convenient to get slightly overlapping geometries. Result lives at
 https://eu.wargaming.net/globalmap/.
 The problem of large slivers is a real thing. I had a lot of it when was
 trying to union and subdivide the GADM polygons.
 Here's an archive of functions before it got packaged as extension:
 https://github.com/wgnet/globalmap/tree/master/code/postgis_wrappers -
 ST_FilterSmallRings was used to get rid of slivers.
 What I've used for slivers was along the lines of
 ST_Safe_Repair(ST_Buffer(ST_Safe_Repair(ST_Collect(ST_Safe_Repair(geom))),0)).
 A solution to the madness was
 https://github.com/postgis/postgis/pull/228/files - I believe Juno still
 uses a build with that thing enabled, but it was reverted upstream.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4182#comment:14>
