[postgis-tickets] r17775 - [drone] Reorganize configuration to use external script
Sandro Santilli
strk at kbt.io
Fri Aug 23 09:03:28 PDT 2019
Author: strk
Date: 2019-08-23 09:03:28 -0700 (Fri, 23 Aug 2019)
New Revision: 17775
Added:
branches/2.5/ci/dronie/
branches/2.5/ci/dronie/postgis_regress.sh
branches/2.5/.drone-1.0.yml
Also add installcheck step
Modified: branches/2.5/.drone-1.0.yml
--- branches/2.5/.drone-1.0.yml 2019-08-23 15:58:43 UTC (rev 17774)
+++ branches/2.5/.drone-1.0.yml 2019-08-23 16:03:28 UTC (rev 17775)
@@ -5,71 +5,30 @@
# See https://git.osgeo.org/gitea/postgis/postgis-docker
# todo: add docker images from https://hub.docker.com/r/postgis/postgis-build-env/tags/
test-image: &test-image docker.kbt.io/postgis/build-test:trisquel2
+clone: &clone
+ image: plugins/git
+ depth: 20
+ recursive: false
kind: pipeline
-name: pg-9.5
+name: build
+clone: *clone
steps:
- - name: build
+ - name: build-9.5
image: *test-image
pull: true
commands:
- - export PGVER=9.5
- - service postgresql start $PGVER
- - export PGPORT=`grep ^port /etc/postgresql/$PGVER/main/postgresql.conf | awk '{print $3}'`
- - export PATH=/usr/lib/postgresql/$PGVER/bin:$PATH
- - psql --version
- - ./autogen.sh
- - ./configure CFLAGS="-O0 -Wall -fno-omit-frame-pointer -Werror" --without-interrupt-tests
- - make -j
- # we should maybe wait for postgresql service to startup here...
- - psql -c "select version()" template1
- - make check RUNTESTFLAGS=-v
- - make install
- - utils/check_all_upgrades.sh
- `grep '^POSTGIS_' Version.config | cut -d= -f2 | paste -sd '.'`
-test-image: &test-image docker.kbt.io/postgis/build-test:trisquel2
-kind: pipeline
-name: pg-9.6
-steps:
- - name: build
+ - PGVER=9.5 sh ci/dronie/postgis_regress.sh
+ - name: build-9.6
image: *test-image
pull: true
commands:
- - export PGVER=9.6
- - psql --version
- - ./autogen.sh
- - make -j
- - make install
-kind: pipeline
-name: pg-10
-steps:
- - name: build
+ - PGVER=9.6 sh ci/dronie/postgis_regress.sh
+ - name: build-10
image: *test-image
pull: true
commands:
- - export PGVER=10
- - psql --version
- - ./autogen.sh
- - make -j
- - make install
+ - PGVER=10 sh ci/dronie/postgis_regress.sh
Added: branches/2.5/ci/dronie/postgis_regress.sh
--- branches/2.5/ci/dronie/postgis_regress.sh (rev 0)
+++ branches/2.5/ci/dronie/postgis_regress.sh 2019-08-23 16:03:28 UTC (rev 17775)
@@ -0,0 +1,20 @@
+#!/bin/bash
+# Exit on first error
+set -e
+service postgresql start $PGVER
+export PGPORT=`grep ^port /etc/postgresql/$PGVER/main/postgresql.conf | awk '{print $3}'`
+export PATH=/usr/lib/postgresql/$PGVER/bin:$PATH
+psql --version
+./autogen.sh
+./configure CFLAGS="-O0 -Wall -fno-omit-frame-pointer -Werror" --without-interrupt-tests
+make clean
+make -j
+# we should maybe wait for postgresql service to startup here...
+psql -c "select version()" template1
+RUNTESTFLAGS=-v make check
+make install
+RUNTESTFLAGS=-v make installcheck
+utils/check_all_upgrades.sh -s \
+ `grep '^POSTGIS_' Version.config | cut -d= -f2 | paste -sd '.'`
