[postgis-tickets] [PostGIS] #4469: ST_ConcaveHull Runtime
PostGIS trac at osgeo.org
Sun Aug 25 07:04:20 PDT 2019
  Reporter:  tsw       |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS GEOS
 Component:  postgis   |    Version:  2.5.x
Resolution:            |   Keywords:
Comment (by tsw):
 Discussions on GEOS Issue 982 suggests that my own testing was incomplete
 so this may in fact be a PostGIS issue.
 dbaston commented:
 " FWIW, if I run ST_ConcaveHull(geom, 0.99) using GEOS master against
  PostGIS trunk, the query takes forever. If I run it using GEOS master
  against the ST_ConcaveHull implementation from PostGIS 2.3.10 it
 completes
  instantly."
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4469#comment:3>
