[postgis-tickets] [PostGIS] #4478: dronie has a bad bot
trac at osgeo.org
Mon Aug 26 10:49:42 PDT 2019
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: blocker | Milestone: Management 2.0
Component: buildbots | Version: 2.5.x
Resolution: fixed | Keywords:
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
I only see timeout problems at the moment, and I raised timeout to 3
hours, which seems mostly fine (still it takes too long to build/test
postgis but we could address that in a separate ticket, maybe to build
with -O2 instead of -O0)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4478#comment:5>
