[postgis-tickets] [PostGIS] #4493: ST_RemoveRepeatedPoints returned geometry bbox might be incorrect
PostGIS trac at osgeo.org
Thu Aug 29 02:38:14 PDT 2019
 Reporter:  Algunenano  |      Owner:  Algunenano
     Type:  defect      |     Status:  assigned
 Priority:  high        |  Milestone:  PostGIS 2.3.11
Component:  postgis     |    Version:  trunk
 Keywords:              |
 When the tolerance is > 0, the resulting geometry bbox might change but it
 isn't updated:
 Example:
 # WITH geom AS
     SELECT ST_RemoveRepeatedPoints('POLYGON((0 0, 10 0, 10 10, 10.5 10.5,
 10 10, 0 10, 0 0))', 1) as g
 Select ST_AsText(g) as geometry, postgis_getbbox(g) AS box from geom;
               geometry              |        box
  POLYGON((0 0,10 0,10 10,0 10,0 0)) | BOX(0 0,10.5 10.5)
 (1 row)
 Time: 0.635 ms
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4493>
