[postgis-tickets] [PostGIS] #4495: Incorrect geometry bbox returned from ST_SnapToGrid
PostGIS trac at osgeo.org
Thu Aug 29 02:49:55 PDT 2019
 Reporter:  Algunenano  |      Owner:  Algunenano
     Type:  defect      |     Status:  assigned
 Priority:  high        |  Milestone:  PostGIS 2.3.11
Component:  postgis     |    Version:  trunk
 Keywords:              |
 Following the #4493 and #4494 drill:
 WITH geom AS
     SELECT ST_SnapToGrid('POLYGON((0 0, 10 0, 10 10, 10.6 10, 10.5 10.5,
 10 10, 0 10, 0 0))', 10) as g
 Select ST_AsText(g) as geometry, postgis_getbbox(g) AS box from geom;
               geometry              |              box
  POLYGON((0 0,10 0,10 10,0 10,0 0)) | BOX(0 0,10.6000003814697 10.5)
 (1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4495>
