[postgis-tickets] [PostGIS] #4493: ST_RemoveRepeatedPoints returned geometry bbox might be incorrect
trac at osgeo.org
Thu Aug 29 03:11:14 PDT 2019
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 2.3.11
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by Algunenano):
> Wait, how do removing _repeated_ points can change the bounding box ?
Because it has a tolerance value, so different points might be removed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4493#comment:2>
