[postgis-tickets] [PostGIS] #4497: Debbie's 2.3 build is broken
trac at osgeo.org
Fri Aug 30 01:47:03 PDT 2019
Reporter: Algunenano | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.3.11
Component: buildbots | Version: 2.3.x
Keywords: |
It seems that at some recent point in the past, Debbie updated its JSON-C
to a newer release and 2.3 doesn't have support for it:
libtool: compile: gcc
-I/var/lib/jenkins/workspace/geos/rel-3.6w64/include
-I/usr/include/libxml2 -I/usr/include -DHAVE_SFCGAL -g -O2 -fPIC -DPIC
-Wall -Wmissing-prototypes
-I/var/lib/jenkins/workspace/geos/rel-3.6w64/include -I/usr/include
-DHAVE_SFCGAL -c lwin_geojson.c -fPIC -DPIC -o .libs/lwin_geojson.o
lwin_geojson.c:36:10: fatal error: json-c/json_object_private.h: No such
file or directory
36 | #include <json-c/json_object_private.h>
compilation terminated.
Support for json-c 0.13+ is available only in 2.4 and onwards.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4497>
