[postgis-tickets] [PostGIS] #4493: ST_RemoveRepeatedPoints returned geometry bbox might be incorrect
trac at osgeo.org
Fri Aug 30 06:31:10 PDT 2019
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 2.3.11
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by Raul Marin):
In [changeset:"17793" 17793]:
#!CommitTicketReference repository="" revision="17793"
Fix ST_RemoveRepeatedPoints output having an outdated bbox
References #4493
Closes https://github.com/postgis/postgis/pull/472
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4493#comment:4>
