[postgis-tickets] r17797 - _postgis_drop_function_if_needed: Update ST_GeoJSON args
Raul
raul at rmr.ninja
Fri Aug 30 07:58:55 PDT 2019
Author: algunenano
Date: 2019-08-30 07:58:55 -0700 (Fri, 30 Aug 2019)
New Revision: 17797
trunk/postgis/postgis_before_upgrade.sql
Related to #4483
Modified: trunk/postgis/postgis_before_upgrade.sql
--- trunk/postgis/postgis_before_upgrade.sql 2019-08-30 13:35:44 UTC (rev 17796)
+++ trunk/postgis/postgis_before_upgrade.sql 2019-08-30 14:58:55 UTC (rev 17797)
@@ -21,7 +21,18 @@
-- Helper function to drop functions when they match the full signature
--- Requires schema, name and __identity_arguments__ as extracted from pg_catalog
+-- Requires schema, name and __exact arguments__ as extracted from pg_catalog.pg_get_function_arguments
+-- You can extract the old function arguments using a query like:
+-- SELECT p.oid as oid,
+-- n.nspname as schema,
+-- p.proname as name,
+-- pg_catalog.pg_get_function_arguments(p.oid) as arguments
+-- FROM pg_catalog.pg_proc p
+-- LEFT JOIN pg_catalog.pg_namespace n ON n.oid = p.pronamespace
+-- WHERE
+-- LOWER(n.nspname) = LOWER('public') AND
+-- LOWER(p.proname) = LOWER('ST_AsGeoJson')
+-- ORDER BY 1, 2, 3, 4;
CREATE OR REPLACE FUNCTION _postgis_drop_function_if_needed(
function_schema text,
function_name text,
@@ -150,7 +161,7 @@
'@extschema@',
'ST_AsGeoJson',
- 'r record, geom_column text, maxdecimaldigits int4, pretty_print bool'
+ $args$r record, geom_column text DEFAULT ''::text, maxdecimaldigits integer DEFAULT 15, pretty_print boolean DEFAULT false$args$
-- FUNCTION ST_LineCrossingDirection changed argument names in 3.0
