[postgis-tickets] [PostGIS] #4600: ST_TileEnvelope default tile is imprecise
trac at osgeo.org
Tue Dec 10 03:14:36 PST 2019
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.1
Component: postgis | Version: 3.0.x
Keywords: |
When checking the initial tile I get integer precision, which is odd to
say the least:
select ST_AsText(ST_TileEnvelope(0, 0, 0));
st_astext
POLYGON((-20037510 -20037510,-20037510 20037510,20037510
20037510,20037510 -20037510,-20037510 -20037510))
(1 row)
Carto's function seems to do this ok:
Select ST_AsText(cdb_xyz_extent(0, 0, 0));
st_astext
POLYGON((-20037508.3427892 20037508.3427892,-20037508.3427892
-20037508.3427892,20037508.3427892 -20037508.3427892,20037508.3427892
20037508.3427892,-20037508.3427892 20037508.3427892))
This seems related to the limited precision of floats, which is how bbox
are stored.
The problem is that this imprecision is found in the base tile, so its
error is translated to all other tiles and becomes evident in any tile
around the borders.
The difference is low for 0/0/0:
Select ST_Area(ST_Intersection(ST_TileEnvelope(0, 0, 0), cdb_xyz_extent(0,
0, 0))) / ST_Area(cdb_xyz_extent(0, 0, 0));
?column?
1
(1 row)
But it's not for certain lower tiles:
Select ST_Area(ST_Intersection(ST_TileEnvelope(18, 262143, 0),
cdb_xyz_extent(262143, 0, 18))) / ST_Area(cdb_xyz_extent(262143, 0, 18));
?column?
0.9784369447535859
(1 row)
That's over 2% error.
Although it isn't great, I suggest recalculating the bbox of the input
geometry the precision of a 64b floating point (vs 32b).
With that, the same tile (18/0/0) is `0.999999996832113` equivalent,
which is what we would expect since CARTO's function uses a slightly
different geometry and algorithm.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4600>
