[postgis-tickets] [SCM] PostGIS branch master updated. e18a0b84dfa0995f3f78d52227aceb3b3e494a52
git at osgeo.org
git at osgeo.org
Wed Dec 11 01:38:09 PST 2019
the project "PostGIS".
via e18a0b84dfa0995f3f78d52227aceb3b3e494a52 (commit)
from 722e45c2dd5c8cc367f0093bc750724687ca2273 (commit)
revisions in full, below.
commit e18a0b84dfa0995f3f78d52227aceb3b3e494a52
Author: Yuri Astrakhan <YuriAstrakhan at gmail.com>
Date: Wed Nov 13 21:41:49 2019 -0500
Add ST_TileEnvelope margin argument
Increase or decrease if negative tile envelope by a given margin
percentage. The result is always clipped according to bounds argument.
Closes #4601
Closes https://github.com/CartoDB/cartodb/pull/15169
Signed-off-by: Raúl Marín <git at rmr.ninja>
diff --git a/NEWS b/NEWS
index 72a22b0..dea80ab 100644
--- a/NEWS
+++ b/NEWS
@@ -8,8 +8,10 @@ PostGIS 3.1.0
* Breaking changes *
- #4577, Drop support for PostgreSQL 9.5 (Raúl Marín)
- #4579, Drop postgis_proc_set_search_path.pl (Raúl Marín)
+ - #4601, ST_TileEnvelope signature changed.
* New features *
+ - #4601, Add ST_TileEnvelope margin argument (Yuri Astrakhan)
* Enhancements *
- #4539, Unify libm includes (Raúl Marín)
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index 87ef1ea..4b8e9a7 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -771,6 +771,7 @@ SRID=4326;POLYGON((75 29 1, 77 29 2, 77 29 3, 75 29 1))
<paramdef><type>integer</type> <parameter>tileX</parameter></paramdef>
<paramdef><type>integer</type> <parameter>tileY</parameter></paramdef>
<paramdef choice="opt"><type>geometry</type> <parameter>bounds=SRID=3857;LINESTRING(-20037508.342789 -20037508.342789,20037508.342789 20037508.342789)</parameter></paramdef>
+ <paramdef choice="opt"><type>float</type> <parameter>margin=0.0</parameter></paramdef>
</funcprototype>
</funcsynopsis>
</refsynopsisdiv>
@@ -780,7 +781,10 @@ SRID=4326;POLYGON((75 29 1, 77 29 2, 77 29 3, 75 29 1))
<para>Creates a rectangular Polygon in <ulink url="https://en.wikipedia.org/wiki/Web_Mercator_projection">Web Mercator</ulink> (SRID:3857) using the <ulink url="https://en.wikipedia.org/wiki/Tiled_web_map">XYZ tile system</ulink>. By default, the bounds are the in EPSG:3857 using the standard range of the Web Mercator system (-20037508.342789, 20037508.342789). The optional bounds parameter can be used to generate envelopes for any tiling scheme: provide a geometry that has the SRID and extent of the initial "zoom level zero" square within which the tile system is to be inscribed.</para>
+ <para>The optional margin parameter can be used to grow a tile by the given percentage, e.g. margin=0.125 grows the tile by 12.5%, which is equivalent to buffer=512 when extent is 4096, as used in <xref linkend="ST_AsMVTGeom" />. This is useful to create a tile buffer -- to include data lying outside of the tile's visible area, but whose existence affects current tile's rendering. For example, a city name (a geopoint) could be near an edge of a tile, but the text would need to render on two tiles, even though the geopoint is located in the visible area of just one tile. Using an expanded tile in a search would include the city geopoint for both tiles. Use negative value to shrink the tile instead. Values less than -0.5 are prohibited because that would eliminate the tile completely. Do not use margin with ST_AsMVTGeom(). See example in <xref linkend="ST_AsMVT" />.</para>
<para>Availability: 3.0</para>
+ <para>Enhanced in 3.1: Added margin parameter.</para>
</refsection>
@@ -794,7 +798,7 @@ SRID=4326;POLYGON((75 29 1, 77 29 2, 77 29 3, 75 29 1))
SELECT ST_AsText( ST_TileEnvelope(3, 1, 1, ST_MakeEnvelope(-180, -90, 180, 90, 4326) ) );
- st_astext
+ st_astext
POLYGON((-135 45,-135 67.5,-90 67.5,-90 45,-135 45))
</programlisting>
diff --git a/doc/reference_output.xml b/doc/reference_output.xml
index 30a87c8..f64b992 100644
--- a/doc/reference_output.xml
+++ b/doc/reference_output.xml
@@ -1189,9 +1189,9 @@ SELECT (ST_AsLatLonText('POINT (-302.2342342 -792.32498)'));
<title>Examples</title>
<programlisting><![CDATA[WITH mvtgeom AS
- SELECT ST_AsMVTGeom(geom, ST_TileEnvelope(12,513,412)) AS geom, name, description
+ SELECT ST_AsMVTGeom(geom, ST_TileEnvelope(12, 513, 412), extent => 4096, buffer => 64) AS geom, name, description
FROM points_of_interest
- WHERE ST_Intersects(geom, ST_TileEnvelope(12,513,412)
+ WHERE geom && ST_TileEnvelope(12, 513, 412, margin => (64.0 / 4096))
SELECT ST_AsMVT(mvtgeom.*)
FROM mvtgeom;
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index adc6d3f..89a395b 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -2051,6 +2051,7 @@ Datum ST_TileEnvelope(PG_FUNCTION_ARGS)
double tileGeoSizeX, tileGeoSizeY;
double boundsWidth, boundsHeight;
double x1, y1, x2, y2;
+ double margin;
/* This is broken, since 3857 doesn't mean "web mercator", it means
the contents of the row in spatial_ref_sys with srid = 3857.
For practical purposes this will work, but in good implementation
@@ -2070,6 +2071,11 @@ Datum ST_TileEnvelope(PG_FUNCTION_ARGS)
elog(ERROR, "%s: Empty bounds", __func__);
srid = gserialized_get_srid(bounds);
+ margin = PG_GETARG_FLOAT8(4);
+ /* shrinking by more than 50% would eliminate the tile outright */
+ if (margin < -0.5)
+ elog(ERROR, "%s: Margin must not be less than -50%%, margin=%f", __func__, margin);
boundsWidth = bbox.xmax - bbox.xmin;
boundsHeight = bbox.ymax - bbox.ymin;
if (boundsWidth <= 0 || boundsHeight <= 0)
@@ -2088,10 +2094,29 @@ Datum ST_TileEnvelope(PG_FUNCTION_ARGS)
tileGeoSizeX = boundsWidth / worldTileSize;
tileGeoSizeY = boundsHeight / worldTileSize;
- x1 = bbox.xmin + tileGeoSizeX * (x);
- x2 = bbox.xmin + tileGeoSizeX * (x+1);
- y1 = bbox.ymax - tileGeoSizeY * (y+1);
- y2 = bbox.ymax - tileGeoSizeY * (y);
+ * 1 margin (100%) is the same as a single tile width
+ * if the size of the tile with margins span more than the total number of tiles,
+ * reset x1/x2 to the bounds
+ if ((1 + margin * 2) > worldTileSize)
+ x1 = bbox.xmin;
+ x2 = bbox.xmax;
+ else
+ x1 = bbox.xmin + tileGeoSizeX * (x - margin);
+ x2 = bbox.xmin + tileGeoSizeX * (x + 1 + margin);
+ y1 = bbox.ymax - tileGeoSizeY * (y + 1 + margin);
+ y2 = bbox.ymax - tileGeoSizeY * (y - margin);
+ /* Clip y-axis to the given bounds */
+ if (y1 < bbox.ymin) y1 = bbox.ymin;
+ if (y2 > bbox.ymax) y2 = bbox.ymax;
PG_RETURN_POINTER(
geometry_serialize(
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 9ad89be..4727552 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -1686,7 +1686,8 @@ CREATE OR REPLACE FUNCTION ST_MakeEnvelope(float8, float8, float8, float8, integ
_COST_LOW;
-- Availability: 3.0.0
-CREATE OR REPLACE FUNCTION ST_TileEnvelope(zoom integer, x integer, y integer, bounds geometry DEFAULT 'SRID=3857;LINESTRING(-20037508.342789 -20037508.342789, 20037508.342789 20037508.342789)'::geometry)
+-- Changed: 3.1.0 - add margin=0.0 parameter
+CREATE OR REPLACE FUNCTION ST_TileEnvelope(zoom integer, x integer, y integer, bounds geometry DEFAULT 'SRID=3857;LINESTRING(-20037508.342789 -20037508.342789, 20037508.342789 20037508.342789)'::geometry, margin float8 DEFAULT 0.0)
RETURNS geometry
AS 'MODULE_PATHNAME', 'ST_TileEnvelope'
LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
@@ -2853,7 +2854,7 @@ BEGIN
THEN
--force install in same schema as postgis only if postgis extension is installed
IF rec.name NOT IN('postgis', 'postgis_topology', 'postgis_tiger_geocoder') AND EXISTS (SELECT 1 FROM pg_catalog.pg_extension WHERE extname = 'postgis') THEN
- sql = 'CREATE EXTENSION ' || rec.name || ' FROM unpackaged SCHEMA '
+ sql = 'CREATE EXTENSION ' || rec.name || ' FROM unpackaged SCHEMA '
|| quote_ident( (SELECT ns.nspname FROM pg_catalog.pg_extension AS e INNER JOIN pg_catalog.pg_namespace AS ns ON e.extnamespace = ns.oid WHERE extname = 'postgis')) || ';';
ELSE
sql = 'CREATE EXTENSION ' || rec.name || ' FROM unpackaged;';
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index c709b05..8780c90 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -187,6 +187,12 @@ SELECT _postgis_drop_function_if_needed
'GeometryA geometry, GeometryB geometry'
+-- FUNCTION st_tileenvelope added a new default argument in 3.1
+SELECT _postgis_drop_function_if_needed
+ 'st_tileenvelope',
+ 'zoom integer, x integer, y integer, bounds geometry DEFAULT ''0102000020110F00000200000052107C45F81B73C152107C45F81B73C152107C45F81B734152107C45F81B7341''::geometry'
-- FUNCTION st_askml changed to add defaults in 3.0 / r17357
-- These signatures were superseeded
diff --git a/regress/core/regress.sql b/regress/core/regress.sql
index 78ab69b..6f5eea3 100644
--- a/regress/core/regress.sql
+++ b/regress/core/regress.sql
@@ -274,7 +274,17 @@ select '232', ST_AsEWKT(ST_TileEnvelope(4, 8, 8, ST_MakeEnvelope(-100, -100, 100
select '233', ST_AsEWKT(ST_TileEnvelope(4, 15, 15, ST_MakeEnvelope(-100, -100, 100, 100, 0)));
select '234', ST_AsEWKT(ST_TileEnvelope(4, 0, 0, ST_MakeEnvelope(-100, -100, 100, 100, 0)));
select '235', ST_AsEWKT(ST_TileEnvelope(4, 8, 8, ST_MakeEnvelope(-200, -100, 200, 100, 0)));
+select '236', ST_AsEWKT(ST_TileEnvelope(0, 0, 0, margin => 0.1));
+select '237', ST_AsEWKT(ST_TileEnvelope(1, 0, 0, margin => 0.1));
+select '238', ST_AsEWKT(ST_TileEnvelope(2, 1, 3, margin => 0.5));
+select '239', ST_AsEWKT(ST_TileEnvelope(0, 0, 0, margin => -0.5));
+select '240', ST_AsEWKT(ST_TileEnvelope(0, 0, 0, margin => -0.51));
+select '241', ST_AsEWKT(ST_TileEnvelope(0, 0, 0, margin => -0.4));
+select '250', ST_AsEWKT(ST_TileEnvelope(10,300,387));
+select '251', ST_AsEWKT(ST_TileEnvelope(10,300,387, margin => 0.1));
+select '252', ST_AsEWKT(ST_TileEnvelope(10,300,387, margin => 0.5));
+select '253', ST_AsEWKT(ST_TileEnvelope(10,300,387, margin => 2));
+select '254', ST_AsEWKT(ST_TileEnvelope(10,300,387, margin => -0.3));
-- Drop test table
DROP table test;
diff --git a/regress/core/regress_expected b/regress/core/regress_expected
index d82fe5c..4b3d7bc 100644
--- a/regress/core/regress_expected
+++ b/regress/core/regress_expected
@@ -203,3 +203,14 @@ ERROR: ST_TileEnvelope: Invalid tile y value, 1
233|POLYGON((87.5 -100,87.5 -87.5,100 -87.5,100 -100,87.5 -100))
234|POLYGON((-100 87.5,-100 100,-87.5 100,-87.5 87.5,-100 87.5))
235|POLYGON((0 -12.5,0 0,25 0,25 -12.5,0 -12.5))
+236|SRID=3857;POLYGON((-20037510 -20037510,-20037510 20037510,20037510 20037510,20037510 -20037510,-20037510 -20037510))
+237|SRID=3857;POLYGON((-22041261 -2003751,-22041261 20037510,2003751 20037510,2003751 -2003751,-22041261 -2003751))
+238|SRID=3857;POLYGON((-15028132.5 -20037510,-15028132.5 -5009377.5,5009377.5 -5009377.5,5009377.5 -20037510,-15028132.5 -20037510))
+239|SRID=3857;POLYGON((0 0,0 0,0 0,0 0,0 0))
+ERROR: ST_TileEnvelope: Margin must not be less than -50%, margin=-0.510000
+241|SRID=3857;POLYGON((-4007502 -4007502,-4007502 4007502,4007502 4007502,4007502 -4007502,-4007502 -4007502))
+250|SRID=3857;POLYGON((-8296781.484375 4852834.453125,-8296781.484375 4891970.21484375,-8257645.72265625 4891970.21484375,-8257645.72265625 4852834.453125,-8296781.484375 4852834.453125))
+251|SRID=3857;POLYGON((-8300695.06054688 4848920.87695312,-8300695.06054688 4895883.79101562,-8253732.14648438 4895883.79101562,-8253732.14648438 4848920.87695312,-8300695.06054688 4848920.87695312))
+252|SRID=3857;POLYGON((-8316349.36523438 4833266.57226562,-8316349.36523438 4911538.09570312,-8238077.84179688 4911538.09570312,-8238077.84179688 4833266.57226562,-8316349.36523438 4833266.57226562))
+253|SRID=3857;POLYGON((-8375053.0078125 4774562.9296875,-8375053.0078125 4970241.73828125,-8179374.19921875 4970241.73828125,-8179374.19921875 4774562.9296875,-8375053.0078125 4774562.9296875))
+254|SRID=3857;POLYGON((-8285040.75585938 4864575.18164062,-8285040.75585938 4880229.48632812,-8269386.45117188 4880229.48632812,-8269386.45117188 4864575.18164062,-8285040.75585938 4864575.18164062))
Summary of changes:
NEWS | 2 ++
doc/reference_constructor.xml | 6 +++++-
doc/reference_output.xml | 4 ++--
postgis/lwgeom_functions_basic.c | 33 +++++++++++++++++++++++++++++----
postgis/postgis.sql.in | 5 +++--
postgis/postgis_before_upgrade.sql | 6 ++++++
regress/core/regress.sql | 12 +++++++++++-
regress/core/regress_expected | 11 +++++++++++
8 files changed, 69 insertions(+), 10 deletions(-)
hooks/post-receive
