[postgis-tickets] [PostGIS] #4602: windows regress failing on ST_TileEnvelope
trac at osgeo.org
Thu Dec 12 06:31:15 PST 2019
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.1.0
Component: postgis | Version: master
Keywords: windows |
Both winnie and my windows regress are failing
quantize_coordinates .. ok in 358 ms
regress .. failed (diff expected obtained:
/projects/postgis/tmp/3.1.0dev_pg12_geos3.8.0_gdal2.4.3w64/test_68_diff)
--- regress_expected 2019-12-11 21:02:17.744362700 -0500
+++ /projects/postgis/tmp/3.1.0dev_pg12_geos3.8.0_gdal2.4.3w64/test_68_out
2019-12-11 21:22:52.072177300 -0500
@@ -210,7 +210,7 @@
ERROR: ST_TileEnvelope: Margin must not be less than -50%,
margin=-0.510000
241|SRID=3857;POLYGON((-4007502 -4007502,-4007502 4007502,4007502
4007502,4007502 -4007502,-4007502 -4007502))
250|SRID=3857;POLYGON((-8296781.484375 4852834.453125,-8296781.484375
4891970.21484375,-8257645.72265625 4891970.21484375,-8257645.72265625
4852834.453125,-8296781.484375 4852834.453125))
-251|SRID=3857;POLYGON((-8300695.06054688
4848920.87695312,-8300695.06054688 4895883.79101562,-8253732.14648438
4895883.79101562,-8253732.14648438 4848920.87695312,-8300695.06054688
4848920.87695312))
-252|SRID=3857;POLYGON((-8316349.36523438
4833266.57226562,-8316349.36523438 4911538.09570312,-8238077.84179688
4911538.09570312,-8238077.84179688 4833266.57226562,-8316349.36523438
4833266.57226562))
+251|SRID=3857;POLYGON((-8300695.06054688
4848920.87695313,-8300695.06054688 4895883.79101563,-8253732.14648438
4895883.79101563,-8253732.14648438 4848920.87695313,-8300695.06054688
4848920.87695313))
+252|SRID=3857;POLYGON((-8316349.36523438
4833266.57226563,-8316349.36523438 4911538.09570313,-8238077.84179688
4911538.09570313,-8238077.84179688 4833266.57226563,-8316349.36523438
4833266.57226563))
253|SRID=3857;POLYGON((-8375053.0078125 4774562.9296875,-8375053.0078125
4970241.73828125,-8179374.19921875 4970241.73828125,-8179374.19921875
4774562.9296875,-8375053.0078125 4774562.9296875))
-254|SRID=3857;POLYGON((-8285040.75585938
4864575.18164062,-8285040.75585938 4880229.48632812,-8269386.45117188
4880229.48632812,-8269386.45117188 4864575.18164062,-8285040.75585938
4864575.18164062))
+254|SRID=3857;POLYGON((-8285040.75585938
4864575.18164063,-8285040.75585938 4880229.48632813,-8269386.45117188
4880229.48632813,-8269386.45117188 4864575.18164063,-8285040.75585938
4864575.18164063))
https://winnie.postgis.net:444/job/PostGIS_EDB_Regress_winnie/10144/console
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4602>
