[postgis-tickets] [PostGIS] #4603: Windows build failing in shp2pgsql: XError in psSHP->sHooks.FWrite()
trac at osgeo.org
Thu Dec 12 09:49:31 PST 2019
Reporter: Algunenano | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.1.0
Component: loader/dumper | Version: master
Keywords: |
From https://winnie.postgis.net:444/job/PostGIS_EDB_Regress_winnie/10146/
There are multiple similar issues:
../loader/Point ........ failed (dumper geog test: dumping loaded table:
/projects/postgis/tmp/3.1.0dev_pg12_geos3.8.0_gdal2.4.3w64/dumper.err)
Initializing...
Done (postgis major version: 3).
Output shape: Point
Dumping: XError in psSHP->sHooks.FWrite() while writing object of 28 bytes
to .shp file: No error
Error writing shape 0
../loader/PointM ... failed ( wkt test: running shp2pgsql output:
/projects/postgis/tmp/3.1.0dev_pg12_geos3.8.0_gdal2.4.3w64/loader.err)
By looking at trunk builds, it seems it started failing at:
Changes
Update the shapelib copy to the latest. References #4591. Required two
(detail)
Generic Cause
Revision: e7c352608c6449ef59d0adad095289038ba27343
origin/master
Which makes sense since shp2pgsql and shapelib are related.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4603>
