[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 531bc44162c2b3636887eee514aa6c5617589415
git at osgeo.org
git at osgeo.org
Thu Dec 12 09:57:58 PST 2019
the project "PostGIS".
The branch, stable-3.0 has been updated
via 531bc44162c2b3636887eee514aa6c5617589415 (commit)
from 6a44fcb9885463754e60a05483099ab18d8bccfd (commit)
revisions in full, below.
commit 531bc44162c2b3636887eee514aa6c5617589415
Author: Raúl Marín <git at rmr.ninja>
Date: Thu Dec 12 16:11:34 2019 +0100
ST_TileEnvelope: Improve precision by calculating the input bbox
Closes #4600
diff --git a/NEWS b/NEWS
index f549ada..d4d946b 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,7 @@ XXXX/XX/XX
- #4588, Fix update when st_union(geometry) doesn't exist (Raúl Marín)
- #4590, Fix pg_upgrade issue with st_linecrossingdirection (Raúl Marín)
- #4599, ST_AddPoint: Accept -1 as a valid position (Raúl Marín)
+ - #4600, Improve precision of ST_TileEnvelope (Raúl Marín)
PostGIS 3.0.0
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 60363fb..b48dc8f 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -2042,6 +2042,7 @@ Datum ST_TileEnvelope(PG_FUNCTION_ARGS)
srid of the object is EPSG:3857. */
int32_t srid;
GBOX bbox;
+ LWGEOM *g = NULL;
POSTGIS_DEBUG(2, "ST_TileEnvelope called");
@@ -2050,9 +2051,17 @@ Datum ST_TileEnvelope(PG_FUNCTION_ARGS)
y = PG_GETARG_INT32(2);
bounds = PG_GETARG_GSERIALIZED_P(3);
- if(gserialized_get_gbox_p(bounds, &bbox) != LW_SUCCESS)
- elog(ERROR, "%s: Empty bounds", __func__);
- srid = gserialized_get_srid(bounds);
+ * We deserialize the geometry and recalculate the bounding box here to get
+ * 64b floating point precision. The serialized bbox has 32b float is not
+ * precise enough with big numbers such as the ones used in the default
+ * parameters, e.g: -20037508.3427892 is transformed into -20037510
+ g = lwgeom_from_gserialized(bounds);
+ if (lwgeom_calculate_gbox(g, &bbox) != LW_SUCCESS)
+ elog(ERROR, "%s: Unable to compute bbox", __func__);
+ srid = g->srid;
+ lwgeom_free(g);
boundsWidth = bbox.xmax - bbox.xmin;
boundsHeight = bbox.ymax - bbox.ymin;
diff --git a/regress/core/regress_expected b/regress/core/regress_expected
index d82fe5c..cde8673 100644
--- a/regress/core/regress_expected
+++ b/regress/core/regress_expected
@@ -196,9 +196,9 @@ ERROR: geometry contains non-closed rings
226|t
ERROR: ST_TileEnvelope: Invalid tile zoom value, -1
ERROR: ST_TileEnvelope: Invalid tile y value, 1
-229|SRID=3857;POLYGON((-20037510 -20037510,-20037510 20037510,20037510 20037510,20037510 -20037510,-20037510 -20037510))
-230|SRID=3857;POLYGON((0 -2504688.75,0 0,2504688.75 0,2504688.75 -2504688.75,0 -2504688.75))
-231|SRID=3857;POLYGON((17532821.25 -20037510,17532821.25 -17532821.25,20037510 -17532821.25,20037510 -20037510,17532821.25 -20037510))
+229|SRID=3857;POLYGON((-20037508.342789 -20037508.342789,-20037508.342789 20037508.342789,20037508.342789 20037508.342789,20037508.342789 -20037508.342789,-20037508.342789 -20037508.342789))
+230|SRID=3857;POLYGON((0 -2504688.54284862,0 0,2504688.54284862 0,2504688.54284862 -2504688.54284862,0 -2504688.54284862))
+231|SRID=3857;POLYGON((17532819.7999404 -20037508.342789,17532819.7999404 -17532819.7999404,20037508.342789 -17532819.7999404,20037508.342789 -20037508.342789,17532819.7999404 -20037508.342789))
232|POLYGON((0 -12.5,0 0,12.5 0,12.5 -12.5,0 -12.5))
233|POLYGON((87.5 -100,87.5 -87.5,100 -87.5,100 -100,87.5 -100))
234|POLYGON((-100 87.5,-100 100,-87.5 100,-87.5 87.5,-100 87.5))
Summary of changes:
NEWS | 1 +
postgis/lwgeom_functions_basic.c | 15 ++++++++++++---
regress/core/regress_expected | 6 +++---
3 files changed, 16 insertions(+), 6 deletions(-)
hooks/post-receive
