[postgis-tickets] [PostGIS] #4604: ST_Intersects discrepancy between 2.5.3 and 3.0.0
trac at osgeo.org
Fri Dec 13 16:00:48 PST 2019
Reporter: paf31 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.1
Component: postgis | Version: 3.0.x
Keywords: |
The following query returns different results between versions 2.5.3
(returns true) and 3.0.0 (returns false) running on Postgres 12.1:
SELECT
ST_Intersects(
ST_GeographyFromText('SRID=4326;POINT(-11.0 0.00005)'),
ST_GeographyFromText('SRID=4326;LINESTRING(-11.0 0.0,-11.0 0.0001)')
The result on 3.0.0 is very sensitive to the numbers used. Changing 11.0
to 10.0, for example, changes the result to true.
We discussed this on IRC and concluded it's probably a bug, so I'm posting
here. Thanks!
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4604>
