[postgis-tickets] [PostGIS] #4608: Geography GIST index fails on table named test
PostGIS trac at osgeo.org
Fri Dec 20 11:59:31 PST 2019
 Reporter:  jgh      |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  low      |  Milestone:  PostGIS 3.1.0
Component:  postgis  |    Version:  3.0.x
 Keywords:           |
 st_contains relying on a GIST index on a geography column fails if the
 table is named public.test.
 It seems to work fine with another table name OR another schema.
 It was observed with st_contains but could affect other functions, though
 at least st_intersects works fine.
 The issue was first reported here:
 https://gis.stackexchange.com/questions/344408/st-covers-fails-on-
 geography-column-with-gist-index-postgis-3-0
 select postgis_full_version();
  POSTGIS="3.0.0 r17983" [EXTENSION] PGSQL="120" GEOS="3.8.0-CAPI-1.13.1 "
 PROJ="Rel. 5.2.0, September 15th, 2018" LIBXML="2.9.9" LIBJSON="0.12"
 LIBPROTOBUF="1.2.1" WAGYU="0.4.3 (Internal)"
 CREATE TABLE test (id SERIAL, the_geog GEOGRAPHY);
 CREATE INDEX test_geog_idx ON test USING GIST(the_geog);
 SELECT id FROM test WHERE ST_Covers(the_geog, ST_GeogFromText('POINT(-0.1
 51.5)'));
 ERROR:  no spatial operator found for opfamily 118328 strategy 7
 CREATE TABLE test1 (id SERIAL, the_geog GEOGRAPHY);
 SELECT id FROM test1 WHERE ST_Covers(the_geog, ST_GeogFromText('POINT(-0.1
 51.5)'));
  id
 (0 row)
 While the impact on a production server is almost nul, having a
 public.test table is fairly common so this issue could affect a large
 amount of users.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4608>
