[postgis-tickets] [PostGIS] #4609: FreeBSD no like check_news.sh script
PostGIS trac at osgeo.org
Sun Dec 22 16:45:05 PST 2019
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.1.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 strk the bessies are not happy with your check script.
 You should have access to both of them if you want to debug the issue. Let
 me know if you don't.
 https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie/1812/consoleFull
 12:09:56 utils/check_news.sh
 12:09:56 usage: date [-jnRu] [-d dst] [-r seconds|file] [-t west]
 [-v[+|-]val[ymwdHMS]]
 12:09:56             [-I[date | hours | minutes | seconds]]
 12:09:56             [-f fmt date | [[[[[cc]yy]mm]dd]HH]MM[.ss]] [+format]
 12:09:56 FAIL: PostGIS 3.0.0 (2019/10/20) appears after Unreleased
 (2019/12/20)
 12:09:56 gmake[1]: *** [GNUmakefile:45: check-news] Error 1
 12:09:56 gmake[1]: Leaving directory
 '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/9df916de87982009fdf0c903125b964e08d33f43'
 12:09:56 *** Error code 2
 12:09:56
 12:09:56 Stop.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4609>
