[postgis-tickets] [SCM] PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots. branch master updated. a71ca2778d041d2196a237a71f3d26297a77f559
git at osgeo.org
git at osgeo.org
Mon Dec 23 07:42:48 PST 2019
the project "PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots.".
via a71ca2778d041d2196a237a71f3d26297a77f559 (commit)
via 5778c1ebb6ff67af0c69ea3219003169ea9e1998 (commit)
from 7b6c600f298a26b4f6ca639ce645113192164349 (commit)
revisions in full, below.
commit a71ca2778d041d2196a237a71f3d26297a77f559
Merge: 5778c1e 7b6c600
Author: Regina Obe <lr at pcorp.us>
Date: Mon Dec 23 10:42:26 2019 -0500
Merge branch 'master' of https://git.osgeo.org/gitea/postgis/postgis-buildbots
commit 5778c1ebb6ff67af0c69ea3219003169ea9e1998
Date: Mon Dec 23 10:40:36 2019 -0500
Add instructions for changing timezone and setting time
diff --git a/freebsd/bessie32_setup.txt b/freebsd/bessie32_setup.txt
index 0681bef..0b0696c 100644
--- a/freebsd/bessie32_setup.txt
+++ b/freebsd/bessie32_setup.txt
@@ -124,4 +124,8 @@ freebsd-version -u #client apps userland -
#if the -u from above still reads 11.1 need to run update install again
freebsd-update install
#reboot
-shutdown -r now
\ No newline at end of file
+shutdown -r now
+#set the time
+ cp /usr/share/zoneinfo/EST /etc/localtime
+ date 1912231036 #sets it to Mon Dec 23 10:36:00 EST 2019
diff --git a/freebsd/bessie_setup.txt b/freebsd/bessie_setup.txt
index 572f772..130d77e 100644
--- a/freebsd/bessie_setup.txt
+++ b/freebsd/bessie_setup.txt
@@ -1,4 +1,4 @@
-Bessie currently setup on winnie's virtual box - ssh port 51022
+Bessie currently setup on winnie's virtual box - ssh port ssh your_user_name at winnie.postgis.net -p 51022
Built from https://download.freebsd.org/ftp/releases/VM-IMAGES/12.0-RELEASE/amd64/Latest/FreeBSD-12.0-RELEASE-amd64.vmdk.xz dated (Dec 2018)
vi /etc/rc.conf
@@ -28,9 +28,10 @@ service sshd restart
#if get host keys not found run
ssh-keygen -A
-To create and add a user robe (repeat for jenkins, pramsey, strk, komzpa, cvvergara) and install relevant ssh keys in homedirs
+To create and add a user robe (repeat for jenkins, pramsey, strk, komzpa, cvvergara, Alguenano) and install relevant ssh keys in homedirs
-adduser robe wheel
+adduser robe
+#when prompted make sure to add to wheel group
#for adds after user created
pw group mod wheel -m robe
@@ -147,3 +148,9 @@ freebsd-version -u #client apps userland
#reboot
shutdown -r now
+#set the time
diff --git a/windows/mingw64/scripts/geos_make_install_check_branch.sh b/windows/mingw64/scripts/geos_make_install_check_branch.sh
index 657791f..ff10ebc 100644
--- a/windows/mingw64/scripts/geos_make_install_check_branch.sh
+++ b/windows/mingw64/scripts/geos_make_install_check_branch.sh
@@ -46,9 +46,9 @@ if [[ "$MAKE_TYPE" == *cmake* ]] ; then
#tools/svn_repo_revision.sh
cd ../
- rm -rf build${OS_BUILD}${MAKE_TYPE}
- mkdir -p build${OS_BUILD}${MAKE_TYPE}
- cd build${OS_BUILD}${MAKE_TYPE}
+ rm -rf build${OS_BUILD}${MAKE_TYPE}${GEOS_VER}
+ mkdir -p build${OS_BUILD}${MAKE_TYPE}${GEOS_VER}
+ cd build${OS_BUILD}${MAKE_TYPE}${GEOS_VER}
export GEOS_ENABLE_INLINE=ON #for older geos
if [[ "${DISABLE_GEOS_INLINE}" == "" ]] ; then
export DISABLE_GEOS_INLINE=ON
Summary of changes:
freebsd/bessie32_setup.txt | 6 +++++-
freebsd/bessie_setup.txt | 13 ++++++++++---
windows/mingw64/scripts/geos_make_install_check_branch.sh | 6 +++---
3 files changed, 18 insertions(+), 7 deletions(-)
hooks/post-receive
