[postgis-tickets] [PostGIS] #4581: installing postgis_raster from unpackaged tries to use wrong schema
trac at osgeo.org
Fri Dec 27 00:41:07 PST 2019
Reporter: robe | Owner: strk
Type: defect | Status: closed
Priority: critical | Milestone: PostGIS 3.0.1
Component: build/upgrade/install | Version: 2.5.x
Resolution: fixed | Keywords:
Changes (by Regina Obe <lr@…>):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"75d0d13258a85da2944ad45ca1ae27ca129906a2/git" 75d0d13/git]:
#!CommitTicketReference repository="git"
revision="75d0d13258a85da2944ad45ca1ae27ca129906a2"
postgis_extensions_upgrade change to allow repackaging
postgis_tiger_geocoder and dealing with non-standard schema postgis
installs. References #4610 and Closes #4581 for PostGIS 3.0.1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4581#comment:8>
