[postgis-tickets] [SCM] PostGIS branch master updated. 478f3023be5ed7e6d3f2841c6e88b65a63700340
git at osgeo.org
git at osgeo.org
Fri Dec 27 00:44:56 PST 2019
the project "PostGIS".
via 478f3023be5ed7e6d3f2841c6e88b65a63700340 (commit)
from ee076579927e37b788a9f0f1f9d2280e96c4ec1c (commit)
revisions in full, below.
commit 478f3023be5ed7e6d3f2841c6e88b65a63700340
Author: Regina Obe <lr at pcorp.us>
Date: Fri Dec 27 03:44:52 2019 -0500
postgis_extensions_upgrade change to allow repackaging postgis_tiger_geocoder. Closese #4610 for PostGIS 3.1.0
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 4727552..ded515c 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -2850,7 +2850,10 @@ BEGIN
JOIN pg_catalog.pg_namespace n ON (c.relnamespace = n.oid )
WHERE n.nspname = 'topology' AND c.relname = 'topology') )
- -- TODO: How do we tell if PostGIS Tiger Geocoder is available ?
+ OR ( rec.name = 'postgis_tiger_geocoder' AND EXISTS (
+ SELECT 1 FROM pg_catalog.pg_class c
+ JOIN pg_catalog.pg_namespace n ON (c.relnamespace = n.oid )
+ WHERE n.nspname = 'tiger' AND c.relname = 'geocode_settings') )
THEN
--force install in same schema as postgis only if postgis extension is installed
IF rec.name NOT IN('postgis', 'postgis_topology', 'postgis_tiger_geocoder') AND EXISTS (SELECT 1 FROM pg_catalog.pg_extension WHERE extname = 'postgis') THEN
Summary of changes:
postgis/postgis.sql.in | 5 ++++-
1 file changed, 4 insertions(+), 1 deletion(-)
hooks/post-receive
