[postgis-tickets] [PostGIS] #4329: PostgreSQL 12 many regression failures rounding and extra warning output
trac at osgeo.org
Thu Feb 21 06:53:22 PST 2019
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.2
Component: postgis | Version: trunk
Resolution: | Keywords: postgres 12
Comment (by robe):
In [changeset:"17267" 17267]:
#!CommitTicketReference repository="" revision="17267"
Change from using CTE to use subquery so results are the same across all
platforms
reason necessary in PostgreSQL 12, CTE changed from being always
materialized to being often inlined.
This means PG12, no longer behaves like old CTE and behaves more like
subquery.
As a result 12 CTE is outputting 4 warnings instead of 1 like older
versions.
Changing to just subquery should force all to output 4 warnings.
references #4329 for PostGIS 3.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4329#comment:8>
