[postgis-tickets] [PostGIS] #4329: PostgreSQL 12 many regression failures rounding and extra warning output
PostGIS trac at osgeo.org
Thu Feb 21 10:26:48 PST 2019
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.5.2
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:  postgres 12
Comment (by robe):
 In [changeset:"17268" 17268]:
 #!CommitTicketReference repository="" revision="17268"
 Missed some spots in last commit
 Change from using CTE to use subquery so results are the same across all
 platforms
 reason necessary in PostgreSQL 12, CTE changed from being always
 materialized to being often inlined.
 This means PG12, no longer behaves like old CTE and behaves more like
 subquery.
 As a result 12 CTE is outputting 4 warnings instead of 1 like older
 versions.
 Changing to just subquery should force all to output 4 warnings.
 references #4329 for PostGIS 3.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4329#comment:9>
