[postgis-tickets] [PostGIS] #4334: Can't upgrade with a view based on ST_AsMVTGeom
trac at osgeo.org
Thu Feb 28 08:19:45 PST 2019
Reporter: Algunenano | Owner: strk
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.4.7
Component: build/upgrade/install | Version: 2.4.x
Resolution: | Keywords:
Comment (by strk):
> The idea is that you pass the complete signature of the old function and
> it will only try to drop it if it matches the one installed, so passing
> the new signature isn't necessary.
You mean if it does NOT match the one installed, right ?
The new signature isn't visible at upgrade time, because we
drop the old one _before_ the new one is installed.
So, to recap: the OLD (current) signature is known, while
the NEW (to be installed) isn't.
> Automating this for all functions looks really complex, but I can
> probably hook the view tests I did above.
A step in that direction would be good, even if it is only a
manually edited sql file creating those constraining views.
We can think about automating the generation of those view
in a second step (I guess it would fail for some upgrade paths
in that we didn't always restrict changes to compatible ones).
Having a test in advance is also good to _prove_ the usefulness
of the code change...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4334#comment:6>
