[postgis-tickets] [PostGIS] #4289: A multipolygon is inverted in ST_AsMVTGeom in some cases
trac at osgeo.org
Wed Jan 9 07:48:40 PST 2019
Reporter: ajolma | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: trunk
Resolution: | Keywords: vector tile
Comment (by Algunenano):
Can you make sure you are using that dev release and also the latest GEOS?
I'm getting correct results:
crap=# Select postgis_full_version();
NOTICE: Function postgis_gdal_version() not found. Is raster support
enabled and rtpostgis.sql installed?
NOTICE: Function postgis_raster_scripts_installed() not found. Is raster
support enabled and rtpostgis.sql installed?
NOTICE: Function postgis_raster_lib_version() not found. Is raster
POSTGIS="3.0.0dev r17118" [EXTENSION] PGSQL="110" GEOS="3.8.0dev-
CAPI-1.12.0 d037cb23" SFCGAL="1.3.6" PROJ="Rel. 5.2.0, September 15th,
2018" LIBXML="2.9.8" LIBJSON="0.13.1" LIBPROTOBUF="1.3.1" (sfcgal procs
from "3.0.0dev r17113" need upgrade)
(1 row)
crap=# SELECT ST_AsText(ST_AsMVTGeom(ST_Transform(problem.geom,
3857), TileBBox(12, 2358, 1093, 3857), 256, 10, TRUE)) geom
FROM problem
WHERE ST_Intersects(TileBBox(12, 2358, 1093, 3857), problem.geom);
geom
MULTIPOLYGON(((217 220,253 198,249 166,266 163,266 254,256 262,255
257,254 255,253 250,249 246,247 241,243 236,242 235,241 236,239 236,238
233,217 220)),((158 225,177 202,194 216,172 242,166 241,158 225)))
(1 row)
Can you share also the output for this query (the one with ST_AsText),
please?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4289#comment:1>
