[postgis-tickets] [PostGIS] #4289: A multipolygon is inverted in ST_AsMVTGeom in some cases
trac at osgeo.org
Wed Jan 9 22:17:24 PST 2019
Reporter: ajolma | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: trunk
Resolution: | Keywords: vector tile
Comment (by ajolma):
I'm sorry, the SELECT was wrong, it should be
SELECT ST_AsMVTGeom(
ST_Transform(problem.geom, 3857),
TileBBox(11, 1180, 547, 3857), 256, 10, TRUE)
INTO test
FROM problem
WHERE ST_Intersects(TileBBox(11, 1180, 547, 3857), problem.geom);
and I just upgraded my GEOS:
POSTGIS="3.0.0dev r17126" [EXTENSION] PGSQL="100"
GEOS="3.8.0dev-CAPI-1.11.0 83b5ecf"
PROJ="Rel. 4.9.3, 15 August 2016"
LIBXML="2.9.4" LIBJSON="0.12.1" LIBPROTOBUF="1.2.1"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4289#comment:2>
