[postgis-tickets] [PostGIS] #4293: Polygon fill-extrusion issue in mapbox with ST_AsMVT created tiles
PostGIS trac at osgeo.org
Fri Jan 11 02:39:30 PST 2019
  Reporter:  joedjc   |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.5.2
 Component:  postgis  |    Version:  2.4.x
Resolution:           |   Keywords:
Comment (by komzpa):
 This looks like reversed order of vertices. What is your PostGIS version?
 (select postgis_full_version();) Can you share the dataset?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4293#comment:2>
