[postgis-tickets] [PostGIS] #4293: Polygon fill-extrusion issue in mapbox with ST_AsMVT created tiles
trac at osgeo.org
Fri Jan 11 03:34:45 PST 2019
Reporter: joedjc | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.2
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by joedjc):
@Algunenano - I am displaying Polygon features using an extrusion style in
Mapbox (really 2.5d rather than full 3D). It would typically be used to
extrude buildings but it uses standard Polygons (see mapbox example:
https://www.mapbox.com/mapbox-gl-js/example/3d-buildings/)
@ komzpa - I am using PostGIS 2.4.4 ("POSTGIS="2.4.4 r16526" PGSQL="100"
GEOS="3.5.1-CAPI-1.9.1 r4246" SFCGAL="1.3.0" PROJ="Rel. 4.9.3, 15 August
2016" GDAL="GDAL 2.1.2, released 2016/10/24" LIBXML="2.9.4"
LIBJSON="0.12.1" LIBPROTOBUF="1.2.1" TOPOLOGY RASTER").
Here is the dataset for the Polygon used in the example:
POLYGON((55.1659679979817 24.9837262257836,55.1678036156365
24.9841294406773,55.1681636731593 24.98353980785,55.1674536009453
24.9826248241092,55.166349678866 24.9828068916502,55.1659679979817
24.9837262257836))
GeoJSON:
{"type":"Polygon","coordinates":[[[55.1659679979817,24.9837262257836],[55.1678036156365,24.9841294406773],[55.1681636731593,24.98353980785],[55.1674536009453,24.9826248241092],[55.166349678866,24.9828068916502],[55.1659679979817,24.9837262257836]]]}
That Polygon isn't following the 'right hand rule', but I tried with one
which does with the same results:
{"type":"Polygon","coordinates":[[[55.1675895300076,24.9860683065305],[55.1657664584022,24.9855976928018],[55.1659753590738,24.9845247978325],[55.1681225482439,24.9849268449059],[55.1675895300076,24.9860683065305]]]}
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4293#comment:3>
