[postgis-tickets] [PostGIS] #4294: ST_AsMVTGeom: Do resolution check before deserializing
trac at osgeo.org
Fri Jan 11 10:54:52 PST 2019
Reporter: Algunenano | Owner: Algunenano
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
In #4161 I added a shortcut to drop small lines and polygons before any
call to the simplification process. I've now noticed that this check could
be done before deserializing the geometry since all you need is the
geometry type and bounding box.
I'll try to move this check to `ST_AsMVTGeom` (C function) before the
`lwgeom_from_gserialized` call and measure its impact in this kind of
input.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4294>
