[postgis-tickets] [PostGIS] #4294: ST_AsMVTGeom: Do resolution check before deserializing
trac at osgeo.org
Mon Jan 14 09:31:49 PST 2019
Reporter: Algunenano | Owner: Algunenano
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by Algunenano):
PR in https://github.com/postgis/postgis/pull/358 @Komzpa thanks a lot for
the comments.
After the changes, on the very best case (polygons with low amount of
vertices that are removed by this shortcut), postgis code only amounts to
~6.75% of the time, or 14.45% if we count its children. Any further
improvement for this case will need to come from the Postgres side (or
something like #4264).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4294#comment:1>
