[postgis-tickets] r17149 - postgis_full_version: Reduce raster notices to debug
Raul
raul at rmr.ninja
Tue Jan 15 02:23:52 PST 2019
Author: algunenano
Date: 2019-01-15 02:23:51 -0800 (Tue, 15 Jan 2019)
New Revision: 17149
trunk/postgis/postgis.sql.in
Closes #4297
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2019-01-14 18:02:29 UTC (rev 17148)
+++ trunk/postgis/postgis.sql.in 2019-01-15 10:23:51 UTC (rev 17149)
@@ -2943,7 +2943,7 @@
END
$$ LANGUAGE plpgsql VOLATILE;
--- Changed: 2.4.0
+-- Changed: 3.0.0
CREATE OR REPLACE FUNCTION postgis_full_version() RETURNS text
AS $$
DECLARE
@@ -2952,16 +2952,15 @@
projver text;
geosver text;
sfcgalver text;
- cgalver text;
- gdalver text;
+ gdalver text := NULL;
libxmlver text;
liblwgeomver text;
dbproc text;
relproc text;
fullver text;
- rast_lib_ver text;
- rast_scr_ver text;
- topo_scr_ver text;
+ rast_lib_ver text := NULL;
+ rast_scr_ver text := NULL;
+ topo_scr_ver text := NULL;
json_lib_ver text;
protobuf_lib_ver text;
sfcgal_lib_ver text;
@@ -2981,31 +2980,29 @@
SELECT @extschema at .postgis_gdal_version() INTO gdalver;
EXCEPTION
WHEN undefined_function THEN
- gdalver := NULL;
- RAISE NOTICE 'Function postgis_gdal_version() not found. Is raster support enabled and rtpostgis.sql installed?';
+ RAISE DEBUG 'Function postgis_gdal_version() not found. Is raster support enabled and rtpostgis.sql installed?';
END;
BEGIN
SELECT @extschema at .postgis_sfcgal_version() INTO sfcgalver;
- BEGIN
- SELECT @extschema at .postgis_sfcgal_scripts_installed() INTO sfcgal_scr_ver;
- EXCEPTION
- WHEN undefined_function THEN
- sfcgal_scr_ver := 'missing';
- END;
+ BEGIN
+ SELECT @extschema at .postgis_sfcgal_scripts_installed() INTO sfcgal_scr_ver;
+ EXCEPTION
+ WHEN undefined_function THEN
+ sfcgal_scr_ver := 'missing';
+ END;
EXCEPTION
- sfcgalver := NULL;
+ RAISE DEBUG 'Function postgis_sfcgal_scripts_installed() not found. Is sfcgal support enabled and sfcgal.sql installed?';
END;
SELECT @extschema at .postgis_liblwgeom_version() INTO liblwgeomver;
SELECT @extschema at .postgis_libxml_version() INTO libxmlver;
SELECT @extschema at .postgis_scripts_installed() INTO dbproc;
SELECT @extschema at .postgis_scripts_released() INTO relproc;
- select @extschema at .postgis_svn_version() INTO svnver;
+ SELECT @extschema at .postgis_svn_version() INTO svnver;
BEGIN
SELECT topology.postgis_topology_scripts_installed() INTO topo_scr_ver;
EXCEPTION
WHEN undefined_function OR invalid_schema_name THEN
- topo_scr_ver := NULL;
RAISE DEBUG 'Function postgis_topology_scripts_installed() not found. Is topology support enabled and topology.sql installed?';
WHEN insufficient_privilege THEN
RAISE NOTICE 'Topology support cannot be inspected. Is current user granted USAGE on schema "topology" ?';
@@ -3017,8 +3014,9 @@
SELECT postgis_raster_scripts_installed() INTO rast_scr_ver;
EXCEPTION
- rast_scr_ver := NULL;
- RAISE NOTICE 'Function postgis_raster_scripts_installed() not found. Is raster support enabled and rtpostgis.sql installed?';
+ RAISE DEBUG 'Function postgis_raster_scripts_installed() not found. Is raster support enabled and rtpostgis.sql installed?';
+ WHEN OTHERS THEN
+ RAISE NOTICE 'Function postgis_raster_scripts_installed() could not be called: % (%)', SQLERRM, SQLSTATE;
END;
BEGIN
@@ -3025,8 +3023,9 @@
SELECT @extschema at .postgis_raster_lib_version() INTO rast_lib_ver;
EXCEPTION
- rast_lib_ver := NULL;
- RAISE NOTICE 'Function postgis_raster_lib_version() not found. Is raster support enabled and rtpostgis.sql installed?';
+ RAISE DEBUG 'Function postgis_raster_lib_version() not found. Is raster support enabled and rtpostgis.sql installed?';
+ WHEN OTHERS THEN
+ RAISE NOTICE 'Function postgis_raster_lib_version() could not be called: % (%)', SQLERRM, SQLSTATE;
END;
fullver = 'POSTGIS="' || libver;
@@ -3119,7 +3118,7 @@
END IF;
IF sfcgal_scr_ver IS NOT NULL AND sfcgal_scr_ver != relproc THEN
- fullver = fullver || ' (sfcgal procs from "' || sfcgal_scr_ver || '" need upgrade)';
+ fullver = fullver || ' (sfcgal procs from "' || sfcgal_scr_ver || '" need upgrade)';
END IF;
RETURN fullver;
