[postgis-tickets] r17150 - Configure: Improve format when printing extension information
Raul
raul at rmr.ninja
Tue Jan 15 03:17:54 PST 2019
Author: algunenano
Date: 2019-01-15 03:17:54 -0800 (Tue, 15 Jan 2019)
New Revision: 17150
trunk/configure.ac
Modified: trunk/configure.ac
--- trunk/configure.ac 2019-01-15 10:23:51 UTC (rev 17149)
+++ trunk/configure.ac 2019-01-15 11:17:54 UTC (rev 17150)
@@ -1523,20 +1523,20 @@
AC_MSG_RESULT()
AC_MSG_RESULT([ --------------- Extensions --------------- ])
if test "x$RASTER" = "xraster"; then
- AC_MSG_RESULT([ PostGIS Raster: enabled])
+ AC_MSG_RESULT([ PostGIS Raster: enabled])
else
- AC_MSG_RESULT([ PostGIS Raster: disabled])
+ AC_MSG_RESULT([ PostGIS Raster: disabled])
fi
if test "x$TOPOLOGY" = "xtopology"; then
- AC_MSG_RESULT([ PostGIS Topology: enabled])
+ AC_MSG_RESULT([ PostGIS Topology: enabled])
else
- AC_MSG_RESULT([ PostGIS Topology: disabled])
+ AC_MSG_RESULT([ PostGIS Topology: disabled])
fi
if test "x$SFCGAL" = "xsfcgal"; then
- AC_MSG_RESULT([ SFCGAL support: enabled])
+ AC_MSG_RESULT([ SFCGAL support: enabled])
else
- AC_MSG_RESULT([ SFCGAL support: disabled])
+ AC_MSG_RESULT([ SFCGAL support: disabled])
fi
if test "x$ADDRESS_STANDARDIZER" = "xaddress_standardizer"; then
@@ -1544,6 +1544,7 @@
else
AC_MSG_RESULT([ Address Standardizer support: disabled])
fi
AC_MSG_RESULT()
AC_MSG_RESULT([ -------- Documentation Generation -------- ])
AC_MSG_RESULT([ xsltproc: ${XSLTPROC}])
