[postgis-tickets] [PostGIS] #4299: st_generatepoints declared IMMUTABLE
trac at osgeo.org
Tue Jan 15 16:33:36 PST 2019
Reporter: pnorman | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.3.x
Keywords: |
On my 2.3 system `st_generatepoints` is declared as `IMMUTABLE`. This is
only valid for functions that always generate the same output given the
same parameters. Random functions should be VOLATILE because they can give
different results each time they are called.
On a closely related matter, it is also marked as `PARALLEL SAFE`, which
might not be true - https://www.postgresql.org/docs/11/parallel-
safety.html says that `random` is `PARALLEL RESTRICTED` because it
accesses "miscellaneous backend-local state which the system cannot
synchronize across workers" and the same might be true for
st_generatepoints
This originates from https://lists.osgeo.org/pipermail/postgis-
devel/attachments/20190115/292e0a64/attachment.html
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4299>
