[postgis-tickets] [PostGIS] #4299: st_generatepoints declared IMMUTABLE
trac at osgeo.org
Fri Jan 18 05:39:33 PST 2019
Reporter: pnorman | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by komzpa):
https://postgis.net/docs/ST_GeneratePoints.html says "ST_GeneratePoints
generates pseudo-random points until the requested number are found within
the input area". There is no guarantee that sequence will be the same or
not the same each time. IMMUTABLE only affects caching in Postgres as for
now, and per current documentation it's okay to cache ST_GeneratePoints
output for the same polygon. Will a note about this behavior be
sufficient?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4299#comment:1>
