[postgis-tickets] [PostGIS] #4299: st_generatepoints declared IMMUTABLE
trac at osgeo.org
Mon Jan 21 16:34:29 PST 2019
Reporter: pnorman | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by Mike Taves):
Another reason for the behavior in the email is because the RNG is
initialized with `srand(time(NULL));`, which means if you re-run the query
multiple times within one clock second, you will get the same results.
(Try it, but you need to be quick!)
I'll try to address this ticket with #4304
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4299#comment:2>
