[postgis-tickets] r17183 - Geodetic tolerance issue in 32-bit
Paul Ramsey
pramsey at cleverelephant.ca
Fri Jan 18 10:03:46 PST 2019
Author: pramsey
Date: 2019-01-18 10:03:46 -0800 (Fri, 18 Jan 2019)
New Revision: 17183
branches/2.4/NEWS
branches/2.4/liblwgeom/lwgeodetic.c
References #4298
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS 2019-01-18 18:02:30 UTC (rev 17182)
+++ branches/2.4/NEWS 2019-01-18 18:03:46 UTC (rev 17183)
@@ -14,6 +14,7 @@
- #4289, ST_AsMVTGeom: Transform coordinates space before clipping (Raúl Marín)
- #4275, Avoid passing a NULL pointer to GEOSisEmpty (Raúl Marín)
- #4296, Use `server_version_num` instead of parsing `version()` (Raúl Marín)
+ - #4298, Geodetic tolerance issue in 32-bit (Paul Ramsey)
PostGIS 2.4.6
Modified: branches/2.4/liblwgeom/lwgeodetic.c
--- branches/2.4/liblwgeom/lwgeodetic.c 2019-01-18 18:02:30 UTC (rev 17182)
+++ branches/2.4/liblwgeom/lwgeodetic.c 2019-01-18 18:03:46 UTC (rev 17183)
@@ -36,6 +36,15 @@
int gbox_geocentric_slow = LW_FALSE;
+* Utility function for ptarray_contains_point_sphere()
+static int
+point3d_equals(const POINT3D *p1, const POINT3D *p2)
+ return FP_EQUALS(p1->x, p2->x) && FP_EQUALS(p1->y, p2->y) && FP_EQUALS(p1->z, p2->z);
* Convert a longitude to the range of -PI,PI
double longitude_radians_normalize(double lon)
@@ -3357,6 +3366,10 @@
POINT3D AC; /* Center point of A1/A2 */
double min_similarity, similarity;
+ /* Boundary case */
+ if (point3d_equals(A1, P) || point3d_equals(A2, P))
+ return LW_TRUE;
/* The normalized sum bisects the angle between start and end. */
vector_sum(A1, A2, &AC);
normalize(&AC);
@@ -3365,7 +3378,7 @@
min_similarity = dot_product(A1, &AC);
/* If the edge is sufficiently curved, use the dot product test */
- if (fabs(1.0 - min_similarity) > 1e-10 )
+ if (fabs(1.0 - min_similarity) > 1e-10)
/* The projection of candidate p onto the center */
similarity = dot_product(P, &AC);
@@ -3374,7 +3387,7 @@
/* the projection of the start point, the candidate */
/* must be closer to the center than the start, so */
/* therefor inside the cone */
- if ( similarity > min_similarity )
+ if (similarity > min_similarity)
return LW_TRUE;
@@ -3409,14 +3422,6 @@
-* Utility function for ptarray_contains_point_sphere()
-static int
-point3d_equals(const POINT3D *p1, const POINT3D *p2)
- return FP_EQUALS(p1->x, p2->x) && FP_EQUALS(p1->y, p2->y) && FP_EQUALS(p1->z, p2->z);
* Utility function for edge_intersects(), signum with a tolerance
