[postgis-tickets] r17184 - Geodetic tolerance issue in 32-bit
Paul Ramsey pramsey at cleverelephant.ca
Fri Jan 18 10:05:36 PST 2019
Author: pramsey
Date: 2019-01-18 10:05:36 -0800 (Fri, 18 Jan 2019)
New Revision: 17184
   branches/2.3/NEWS
   branches/2.3/liblwgeom/lwgeodetic.c
References #4298
Modified: branches/2.3/NEWS
--- branches/2.3/NEWS	2019-01-18 18:03:46 UTC (rev 17183)
+++ branches/2.3/NEWS	2019-01-18 18:05:36 UTC (rev 17184)
@@ -14,7 +14,9 @@
   - #4275, Avoid passing a NULL pointer to GEOSisEmpty (Raúl Marín)
   - #4296, Use `server_version_num` instead of parsing `version()` (Raúl Marín)
+  - #4298, Geodetic tolerance issue in 32-bit (Paul Ramsey)
 PostGIS 2.3.8
 2018/11/24
Modified: branches/2.3/liblwgeom/lwgeodetic.c
--- branches/2.3/liblwgeom/lwgeodetic.c	2019-01-18 18:03:46 UTC (rev 17183)
+++ branches/2.3/liblwgeom/lwgeodetic.c	2019-01-18 18:05:36 UTC (rev 17184)
@@ -36,6 +36,15 @@
 int gbox_geocentric_slow = LW_FALSE;
+* Utility function for ptarray_contains_point_sphere()
+static int
+point3d_equals(const POINT3D *p1, const POINT3D *p2)
+	return FP_EQUALS(p1->x, p2->x) && FP_EQUALS(p1->y, p2->y) && FP_EQUALS(p1->z, p2->z);
 * Convert a longitude to the range of -PI,PI
 double longitude_radians_normalize(double lon)
@@ -3059,6 +3068,10 @@
 	POINT3D AC; /* Center point of A1/A2 */
 	double min_similarity, similarity;
+	/* Boundary case */
+	if (point3d_equals(A1, P) || point3d_equals(A2, P))
+		return LW_TRUE;
 	/* The normalized sum bisects the angle between start and end. */
 	vector_sum(A1, A2, &AC);
 	normalize(&AC);
@@ -3067,7 +3080,7 @@
 	min_similarity = dot_product(A1, &AC);
 	/* If the edge is sufficiently curved, use the dot product test */
-	if (fabs(1.0 - min_similarity) > 1e-10 )
+	if (fabs(1.0 - min_similarity) > 1e-10)
 		/* The projection of candidate p onto the center */
 		similarity = dot_product(P, &AC);
@@ -3076,7 +3089,7 @@
 		/* the projection of the start point, the candidate */
 		/* must be closer to the center than the start, so */
 		/* therefor inside the cone */
-		if ( similarity > min_similarity )
+		if (similarity > min_similarity)
 			return LW_TRUE;
@@ -3111,14 +3124,6 @@
-* Utility function for ptarray_contains_point_sphere()
-static int
-point3d_equals(const POINT3D *p1, const POINT3D *p2)
-	return FP_EQUALS(p1->x, p2->x) && FP_EQUALS(p1->y, p2->y) && FP_EQUALS(p1->z, p2->z);
 * Utility function for edge_intersects(), signum with a tolerance
