[postgis-tickets] [PostGIS] #4272: Improve "unable to compute statistics" notice message
trac at osgeo.org
Mon Jan 21 03:40:34 PST 2019
Reporter: Algunenano | Owner: Algunenano
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by Algunenano):
Github PR: https://github.com/postgis/postgis/pull/364
It does 2 things:
- Outputs table and geometry name when the error occurs.
- Doesn't call `compute_gserialized_stats_mode` the second time (for N
dimensions) if the first one (for just 2 dimensions) failed.
Before:
# analyze;
NOTICE: no non-null/empty features, unable to compute statistics
ANALYZE
After (as n-d isn't called there are half the log messages):
# analyze;
NOTICE: PostGIS: Unable to compute statistics for
"krakow_final.the_geom": No non-null/empty features
"krakow_final.the_geom_webmercator": No non-null/empty features
"lion_nyc_streets_lat_lon_enumerated_wkt.the_geom": No non-null/empty
features
"lion_nyc_streets_lat_lon_enumerated_wkt.the_geom_webmercator": No non-
null/empty features
ANALYZE
Since I expect that someone might be relying on the log string to not
change between minor releases I'm not planning on backporting this.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4272#comment:2>
